I bought some Ground controls and i have like 20 o rings… about 6 of them are twice as fat. I know in the diagram they say to use one /each shock. But there is so many!!
What are their purpose? Im confused.
I didnt really thoroughly search but i did a quick one and didnt find anything. Sorry just in a sort of rush.
its to help center out the adjusting perch if u got the coil-overs and to help prevent it from moving around when you hit small bumps, it also helps absrob the shock slightly.
absorb shock? what shock? They’re just there to snugly fit the collar over the shock body. And there are a lot of 'em cause then you can pick and choose which to use. They probably put the same o-ring in all their boxes for different applications. Some cars have diff dia shocks, so they will need diff sized o-rings.
