Alright, I just picked up some jdm one pieces from a buddy. I haven’t installed them on my car yet, but I decided to hook them up to a battery to make sure the lights work. Headlights are fine, they’re a soft blue/light white color… the outside lights (Running light, yes?) Work, and are a bright amber…
but the fogs… they prettymuch match the headlights. There isn’t a hint of yellow. I removed the 2 screws on top of the fog and popped the bulb out… the bulb itself is clear. Looking from the front, the reflector is still installed. Soooo… has someone previously opened the lights and removed the yellow capsuls? Or are the bulbs supposed to be colored… or…? I’m kinda irritated by this as having yellow fogs actually works well in the snow we have here.
Are these like the legend foglights? Can I swap my legend setup from my usdm lights to the jdm ones? I’m kinda confused.
yup. but wasn"t it a trend a while ago toseperate the lenses and remove those capsules? I seem to remember there being a write up or something about it. maybe you have one of modded ones
Did all JDM headlights come with yellow fog capsules?
My JDM headlights do not have the yellow fog capsules installed. Can these be installed from the back of the housing? Or must the light housing come apart and the capsules insalled from the front?
I really don’t want to risk breaking something, so could I just buy some 35watt yellow H3s and use those? Will they look decent?
I’m still not sure whether or not my password:jdm harness is correct… Could a member here with 1-pieces tell me which colors you have running which pins? I know the ground goes to the left side, but the other two I’m not positive of.
