hey all,
recently while reviving my 91 GS, i began removing the ABS System. Did a four wheel brake job and when i got to my final caliper, the LF. the Caliper was seized in place. So figuring the vehicles age , and the likeliness of the other size failing, i Purchase the Wilwood DPHA Direct bolt on 4Piston caliper kit for the fronts. They claim it will clear the factory EM1 15" wheel which is, from what i can find , a 15X6.5 ET45… The reason i as is i would like to get a set of wheels, specifically the DRAG DR-27, which comes in 15X7 with an offset of +10, and i dont want to end up having clearance issues. If anyone has had an experience with the brake kit , or with clearance with wheels like this offset and width, i could use the input! thank you!!
