So here is my two year long nightmare:
I purchased a '92 DA9 GS two years ago. On the first drive, it had very soft brakes, with the pedal nearly dropping to the floor. I assumed it was either a bad master cylinder, or air in the system, or old brake lines, or even a combination of many things. I bought the car with the intention of making it my new daily driver.
Once I had the car home, I did a little inspection and found some serious brake work was needed. I replaced the master cylinder with a remanufactured product from PartSource, swapped in Russell stainless steel lines, four new calipers, Hawk HPS pads in all four corners, and Eurorotors in all four corners. I then bled the entire system with Prestone DOT4.
The master cylinder was bench bled before installation with a bench bleeding kit. After installation, the brake system was bled properly: the brake pedal was depressed, then I open the bleed screw until the fluid stops flowing, then I close it firmly, then the pedal is released. Repeat, repeat, repeat until no air, then move to the next brake. The bleeding process was in the order of: rear right, front left, rear left, front right - with somebody depressing the brake pedal for me.
The pedal feels exceptionally firm, right at the top of the pedal stroke - until you start the engine. With the booster under vacuum, the pedal sinks very loosely 4/5 of the way down, with the remaining travel offering minimal resistance. Driving the car is a nightmare, where I must augment my braking with the handbrake, which provides a dramatic difference, but no more than what you would expect for a handbrake.
I assumed the master cylinder was faulty and exchanged it at PartSource. I bench bled the new master cylinder and reinstalled. I bled the entire brake system with new fluid. The pedal became exceptionally hard, but as soon as the engine was started, I found the same soft pedal as before. I checked all the connections, found no leaks and could see no loss in fluid at the reservoir. I asked some advice, including the staff at PartSource and thought it could be a bad batch of master cylinders, so I returned/refunded the one I had.
I went to my crashed DB2 parts car and pulled the master cylinder off. It worked fine when it drove, so I hoped it would still be okay. I installed by the same process as above, and found the same soft pedal after starting the engine. I then thought it could be something to do with the ABS system.
I (carefully) drove the car to the nearest Honda dealership and asked for the ABS system to be flushed and tested. They called me back reporting the ABS system flushed and tested out okay, but that the brake pedal was soft, most likely due to air in the system. I explained I was having difficulty with it for some time and was not able firm up the pedal; I asked them to bleed the system. The dealership bled the brakes with Honda DOT3 fluid and called back reporting no change to the pedal response. They claimed the master cylinder was faulty and wanted to change it. I explained that the current master cylinder was the third installed, etc., etc. but they insisted that a Honda master cylinder, at $350 plus install, would do the trick. Desperate, I initially agreed, but fortunately, a non-ABS master was delivered so they had to reinstall the original, saying there would be a delay until the correct part arrived. I cancelled the job and took the car back.
After a lot of consideration, I ordered a brand new, genuine Honda master cylinder from a dealership in the US for $220ish delivered and installed it myself with the assistance of an experienced Integra enthusiast, only to be back with the same problem.
I began to suspect the solenoids in the modulator were failing, despite the results from the Honda dealership’s tests. I removed and replaced the entire ABS’s mechanical system as a whole from the DB2 and installed into the DA9 - that is, the modulator, pump, accumulator, etc., without opening either system (took a long, long time). I bled the entire system again, to get the same soft brake pedal.
I examined the calipers closely and thought there was too much play with the guide pins. When the brake was depressed, the caliper was not moving with linear motion, but rather a slightly curved motion. My girlfriend’s DB1 needed front calipers, so we agreed to use these calipers to see how they worked on her car. Once installed and bled, her brakes work fine. I installed the second, new (remanufactured) calipers on my DA9, bled, soft pedal. As a note, the rear calipers appear to be functioning normally and the handbrake is tight and responsive.
I then suspected my stainless steel brake lines. I removed them from my DA9 and put them on my girlfriends DB1. Once bled, her brakes work great. I bought new stainless lines, installed, bled, soft pedal.
I removed the master cylinder and inspected everything closely. I found two extra gaskets between the master cylinder and booster, two were old and swelled up, stuffed right into the booster and the one closest to the master cylinder was new and firm, staying on the master cylinder’s rod. I pulled the two old ones out, cleaned everything as best as I could and examined the booster for mechanical problems. I compared the booster with another I had handy and found no dissimilarities. I reinstalled everything, bled the entire brake system and got the same soft pedal after starting the engine. I checked the vacuum hoses and check-valve, everything was operating normally.
It’s been two years.
Seriously, what the hell?
