So my brake light and horn fuse keeps blowing. I’ll change it and the lights will work as will the horn and then just one day blow. I thought maybe a wire behind the bumper was broken/bare but I pulled the bumper and all the wires looked good. This just started happening out of no where
It varies with how long it takes and I really can’t pinpoint it exactly I’ll randomly test the horn and sometimes it will work then one time it won’t work and I’ll know the fuse was gone but I have no idea if it’s the brake lights, horn, or a wire problem.
Because both the horn and brake light circuits are on the same fuse, you will have to isolate the circuits, I would unplug the horn relay, [go without a horn for a bit] and see if fuse still blows.
If fuse still blows, you know the short is in the brake light circuit and you will need to check it. 94
