Alright well the brake light on my gauge cluster just randomly turned on and stays on… Check to see if maybe i had the emergency brake up and no that wasnt it… do yall have any advice… if so LMK please!!!1
not completely sure, but it could be a short in the wiring or maybe theres something wrong with ur brakes
Pull the center console and check the switch for the ebrake. It might be stuck.
dont listen to them ^^^^ check your brake fluid when the light stays on its you low fluid warning
:rimshot:
yapp check your brake fluid it might be low that will cause your light to tun on. i know its annoying to see a brake warning light on while drving. &^^
alright will do! thanks
this!
