Brake Light Problem NEW 1
well my brake light is not working and i tried to found out what it is i change all my bulbs wasn’t it changed the brake switch wasn’t it look at the fuses on the inside wasn’t it then i looked at the fuse under the hood it was a 15 fuse for the stop.horn fuse i think that not the right fuse think it 20 right? so i put in a 20 fuse didn’t work BUT i look at the 20 fuse and it blew out so i put another 20 turn on then step the brake light didnt work THE FUSE BLEW OUT AGAIN sorry im new at posting and i need help search but they didn’t have the information i was looking for on it. some 1 pls help me on how to fix my brake light the 20 fuse for the stop.horn fuse keep blowing out when i step on brakes what is it?
if you need more info. reply THANK YOU
You are correct, the brake light fuse is a 20A, fuse 37 - 20A, [hot at all times] in under hood fuse box.
You have a short, after the brake light switch, on the green/white brake wire, you will need to pull the drivers kick panel, find the plug for the rear harness, [it runs down drivers side of car, the plug will be around or plugged into the under dash fuse box] and unplug it, try another fuse, if fuse still blows problem is between switch and fuse box, [or plug], if fuse does not blow the problem is between fuse box, [or plug] and the brake lights.
Fallow the harness to the rear of the car inspecting it as you go, look for frayed or pinched wires, concentrate any place where car has been in an accident or where you have done any work.:whisper:94
YESSSSS!! i finally got it fix I did what fcm said follow the wire unplug and all that turns out it was 1 of my tail light wire it was pinched thought it wasn’t by just looking at it but took it off and BAM problem found and solved thanks alot fcm
:bowthank: 94
