brake lights issue
for some reason when i turn off my lights the brake lights stay on
and the back blinkers dont work but the fronts do
i have replaced the brake light switch behind the pedel
replaced all the lights and got used harness for both sides from salvage yard
and pulled the ground cable and cleaned it up
if anybody knows about ths problem please respound i have been searching
on here for few hours now
and it’s not the fuse that is the first thing i checked
On the brake lights do they always stay on ? if so try this there is a littlle round plastic piece on the peddle that touch the swich to push in on the switch when the brakes are off i will try a post a pic. any ways mine had broke an my light stayed on so once i got the new little buttob piece i was good to go
Ya it’s for sure that plastic stop on the pedal. Look on your floor, it’s probably in like 3 pieces lol
finally found a few write ups on this issue thanks for the replys
http://forums.g2ic.com/showthread.php?115901-Brake-light-stuck-on&highlight=lights%20stay
sure enuff the rubber stop fell off and the switch goes thru the hole so the switch does not press in and kill the lights
