brake lights stay on
hey guys, i cant figure out why my brake lights always stay on even when the car is off. i have to take off the negative terminal every time i dont drive the car or else itll drain my battery -__-
any help would be greatly appreciated it
Search next time.
http://forums.g2ic.com/showthread.php?208690-My-brake-lights-stay-on-when-car-is-off&highlight=Brake+lights
http://forums.g2ic.com/showthread.php?202385-brake-lights-stuck-on&highlight=Brake+lights
http://forums.g2ic.com/showthread.php?168346-Brake-lights-stay-on-and-have-to-jump-the-car&highlight=Brake+lights
http://forums.g2ic.com/showthread.php?115901-Brake-light-stuck-on&highlight=Brake+lights
[QUOTE=spikeymike;2266456]Search next time.
http://forums.g2ic.com/showthread.php?115901-Brake-light-stuck-on&highlight=Brake+lights[/QUOTE]
Thank you very much
Thank you again G2IC! After getting my smog done, I thought the techs had screwed with my car somehow because my brake lights stayed on and my battery fully drained. I did a search, found this thread with the multiple results, and sure enough after looking around on the floor mat, I found the broken plastic pieces. I disconnected the battery until the replacement ‘plug’ came in, and that fixed it. It all works again.
I spend a lot of my time on nsxprime now (hint hint), but my DA is still my daily and thank God you can find answers quickly on here!
