ok i just got done dealing with the brake pedal sinking problem.(master cylinder). i just put on a master cylinder and the pedal doesnt sink, but after bleeding the brake pedal still sit hella low. my brakes work but i just wanna get the pedal back, can someone help???
BTW i searched and all i come up with is change master cylinder which obviously i did
Try bleading them some more. Start with the wheel furthest from the master cylinder and work your way in. If this doesn’t help check the thickness of your pads. Sometimes thin brake pads will give you low pedal travel.
alright man thanx
