My brakes have been sqealing but I don’t think they should be worn out yet… the fliud is on the low mark though so maybe the pads are worn to make the fliud level go down. But the pedal has been going to the floor sometimes, it still stops the car, sometimes it acts normal but when it gets warmed up as I slow down the pedal slowly drops to the floor. I can let off and pump the pedal if I need to. Well I don’t have time to check the pads in the next few days so I added some brake fluid. I’ll see how it does tomorrow I guess.
Don’t assume anything. Brakes are the most important system in the car. Inspect your pads for wear - most likely they are worn down. I would also advise in doing a brake bleed of your system.
Regards,
Oz
check for leaks anywhere, if you dont find any its a good chance theres an internal leak in the master cylinder. if thats the case your gonna need to replace it.
It is hard to check for leaks because brake fluid evaporates pretty quick. I’ll have to see if I can get my car on the ramps or get the jack under it since I lowered it:(
