brake upgrade problem
I purchased the fastbrakes rear caliper relocation kit that lets you use your stock caliper but put 11" rotors in the back. I was planning on buying a front big brake kit also but lost my job. Now this rear kit is just sitting there. Can I install this kit and keep my front brakes stock and brake safely? Or will this throw the balance of the car all off when braking and send me into a wall?
i would at least get a more aggressive pad for the front and put an OEM or equivalent on the back. you wont have more braking power with bigger rotors they just dissipate heat faster, which will leave your front brakes fading faster than the rears (the rears hardly fade anyway).
on top of the pad staggering, i would definitely change your brake fluid to something a little less prone to boiling than OEM grade fluid. valvoline makes a good one.
this is all assuming that you track/drive your car hard. on the street, under normal commuter conditions, you wont notice any of the shit i was just saying, and i would just leave the brakes alone until you can afford to do the whole setup. hondas are already extremely front biased with their brakes, with your new rear setup you MIGHT notice itll be easier to trail brake into corners. but the difference will pretty much only be there.
i bought the brake setup for my last car from two different places so i received the rear setup (OEM Jaguar S-type R rear setup) before the brembo big brake kit for the front, i had so much fun lift-oversteer and trail-braking into corners. its not dangerous to run upgraded rear brakes, but just be careful when youre driving at the limit of your car. it can get squirrely
Hey man thanks for the help! How bout I put crossdrilled or slotted disc in front with more aggressive pads. Would that help even out the braking? Cause the way the job market is it might be along time before I can get bigger brakes in front
tbh, if you track your car at all, drilled rotors WILL crack at elevated temperatures. bigger two peice brakes with seperate hats and rotors dissipate heat a lot better and can get away with it, but OEM replacement drilled rotors are a bad idea (IF you track your car). if its just a daily commuter you will notice better pedal response and less effort so id say depending on how you drive will determine what you do brake-wise
are you just looking for bling or better braking? have you tried more aggressive pads and new blank OEM style rotors? also, flush your brake system and use a better fluid (unless youre running a good fluid already), maybe stainless braided brake lines too, youd be suprised how much flex the lines have after 20 years.
a refreshed, mostly OEM braking system is usually enough to stop a mildly built DA better than the 20 year old factory parts.
I got motul 5.1 brake fluid and steel lines already. I just have this rear kit laying around and wanted to know if it would be safe to put it in without upgrading the front. But like you suggested I will put better pads up front. What you think of hawk pads?
the HPS pads are great for daily drivers, altho they fade pretty easy under stress.
the HP+ are great if you dont care about brake dust or noise. they WILL turn your rims brownish grey aha.
what pads would you recomend?
how do you drive your car?
I only really drive my car on da weekends. Its mainly a fun car. I would really like to take it out on a road coarse if I could find a good cheap place to do so.
I’d recommend AGAINST that rear brake kit. Many of the Honda challenge road racers run OEM pads for their race cars. I have HPS rear pads, and I can get bad oversteer on downhill road course turns without holding the car perfectly straight under braking. I do have a very aggressive rear swaybar.
If you take your car to an empty parking lot and succeed to do handbrake turns, your rear brakes are probably good enough.
whoa! thats crazy! so I could spin out even from braking on a freeway ramp or something like that?
how bout da cheapest autozone pad in the rear and get some
EBC street/track pad in the front
