I just did a abs delete no leaks in lines or anything the only problem is that my brakes are staying stuck closed so they are always engaging is there any problems that anyone else may have had after doing a abs delete?
Did you change the brake booster and the MC? Non abs Tegs have smaller size booster and MC.
Ng
did you keep the abs booster and change to the non abs mc…you have to use both from the same vehicle, abs booster and mc, non abs booster and mc. hope that helps.
