would these cams cause problems on a non turbo engine? i accidentally bought the wrong set of cams because i thought they were the 0022 set. they say that you can use them on a nitrous engine, so would it be ok for a n/a engine? any help would be greatly appreciated.
Probably. “turbo” cams are usually just optimized for use with boosted applications. What other modifications do you have?
engine wise, just intake header and exhaust at the moment.
I’m no expert on the subject of bc0021 running NA. However, I was interested just like you so I found this on the net: http://www.nonvtec.com/forums/new-b18b1-t314.html-view=next&sid=99a620c2a35f4e03dcefad3c12550d3e
BTW, how much did you pay for those bc0021 (and where)? I want a pair but money is tight.
I hope it helps!~
i got them used off ebay for 150
