Broke my speedo cable...HELP! what to do now
well…yes I am a moron. I broke my speedo cable. Can I buy and new one and put it in? How much would it cost? I’m so pissed about it. Any help would be great.
Yes you can buy and replace it. The cable should be anywhere from 20 to 30 bucks depending on dealers. Wat part did you break? the sheath covering or the actual cable in the middle?
Now when you get pulled over and the cop asks you “Do you know how fast you were going?”, you can really say…“Well no I don’t Officer.” :smiley: :stuck_out_tongue:
-Steve
replaced mine the other day. from my exp, if you want indiglo gauges now is a good time because you have to take out the guages and pull the cable through the firewall. make sure you tie a line at the end of the cable so when you install the new one, you can fish it through the firewall. less trouble that way. good luck to you.
did you break it installing indiglos? i was worried i almost was with all the force i used…
i believe its 37 dollars from the acura dealer around here
got mine for $24.35 from ahmotor.com
I tryied taking it out to paint the dash black, but ended up pulling the wrong thing, so…I need a new one now. Thanks for your help.
