broken radiator low funds what radiators fit??
my radiator is super leaking and im a bit on the broke side and need a new/working radiator so which will fit in my teggie??
anyone wanna hook it up?
located in sj :sad:
Pick n pull?
why don’t you just get it fixed ? you can do it yourself if a tank is cracked by buying a tank repair kit. if a vein is cracked, take out the rad and get it soldered for like 10 bucks. you can even jb weld it or pinck off the veins on either side. if it is leaking from the seams, just have a radiator shop resolder the seams. sometimes they’ll do it for cheap. good luck!
worse comes to worse, throw a raw egg in there and let it circulate
raw egg ? what does that do ?
It cooks inside the radiator and clogs the leak. Unfortunately it clogs the whole thing. My friend blew his head gasket after the raw egg “trick”.
was at pick n pull saturday nothing >.> found a lot of those bmw bottle cap wheels though lol nothing useful
i’ve tried using that radiator leak stopping stuff but i have school and whatnot so i don’t have as much time during the week to take out the radiator. if its a small leak wont it only leak when its pressurized? how do you suppose i find it if thats the case? cause my cars just been sitting in the garage and doesn’t really leak. drove about 40 miles had to put more fluid it got home after 40 more miles and i could see the whatever in the radiator forgot what its called.
no it didn’t. i can almost guarantee it.
If you decide to buy a new radiator, one option is the inexpensive aftermarket ones sold on eBay. I’ve had one of those in my car for about 8 years now, and it has never leaked and works great. Made in China, but the quality is pretty darn impressive. I think it was about $120 including shipping. I don’t think you’re going to get a new radiator cheaper than that.
[QUOTE=lilvietboy;2078974]was at pick n pull saturday nothing >.> found a lot of those bmw bottle cap wheels though lol nothing useful
i’ve tried using that radiator leak stopping stuff but i have school and whatnot so i don’t have as much time during the week to take out the radiator. if its a small leak wont it only leak when its pressurized? how do you suppose i find it if thats the case? cause my cars just been sitting in the garage and doesn’t really leak. drove about 40 miles had to put more fluid it got home after 40 more miles and i could see the whatever in the radiator forgot what its called.[/QUOTE]
are you sure that your water pump isn’t leaking? radiator shops will usually do a pressure test on your radiator for free.
pretty sure its the radiator because i’ve had it leaking before and than i added bar leaks and it stopped leaking for awhile (guessing it was a small crack in the rad) than it came back a few months later my water pump and timing belt were replaced a month before i bought my car (got it from my cousin) and than it started leaking again and it leaks right at the bottom of the radiator.
sorry for the confusion it does leak even when its off but not as much as when the engines hot
I guess the fact that he overheated it was really the reason the gasket blew. I’m not saying the egg caused the overheat, I’m just saying if I made a list of options of ways to go about fixing it I would put it right at the bottom just like you did above.
duane yeah i was looking at those.
thanks everyone for the advice i thought the radiator was going to kill me but i managed to get a discount for a radiator same day shipping and all for 60~80 hopefully its 60. getting the employee discount yee
