Brown Box Behind Center Console?
if you take the center console interior piece off, there is a brown box mounted on the dashes frame. it would be right behind where the cd player goes.
just curious, what does this box do?
it sounds like your talking about the (MFR) main fuel relay but that is more under the steering wheel.
thats not what i was talking about but i think i figured it out…i think its the chime and door sensor. it makes the chime sound when the doors open
Resistor box? Looks like a lil tiny amp right?
the box says ‘inter lock control’ on it and it has a smaller silver box on it. i went to the junkyard today and found some DAs with just the silver box and some had both the brown box and silver box. I dont know if theres a difference between 2dr and 4dr or it the car has power locks or manual locks. they were all mixed up at the junkyard
i found out that the box is for automatics so i dont need to use it. but now im left with a 4 wire plug that i dont know where it goes.
the plug had 4 wires: wht/blu, wht/blu, ylw/red, black
anyone know what it goes to?
thanks
could be the clicker??? I had to replace my turn signal relay in my '92 ls (manual) and this is a picture of what they gave me, it worked! the original turn signal relay was smaller. I guess the only difference would be that it was located under the driver side dash and not behind the radio.
