Build A Short Shifter
Just thought i would tell you guys that if you don’t want to spend ANY money on a short shifter and can or know someone who can weld, you can simply weld a longer bottom arm onto a shift rod and you’re all set. I believe that the max you can go is 3 inches without hitting the muffler piping. You will still need to remove th heat shield though.
