Today I just went to visit a knowledgeable mechanic. He told me that I have to balance the crankshaft, then after putting everything together, balance the complete bottom end. This lead to some pricey figure.
I’ve also been told I need many special measuring tools to measure various clearances, etc.
Then another mechanic told me that as long as no significant machining was done, I just need a torque wrench, along with just honing the cylinder walls.
NOW, THIS IS THE CASE. I am putting together a bottom end with B16 pistons for higher compression. (spun a bearing on my current bottom end, and have no money)
ALL I WANT is to be able to rev to about 7500 with peace of mind. I presume I need to buy new rings, bearings, etc…
My question is, do I need to do all that balancing with the block? I mean, itz not like I’m revving to 9000rpm…
Basically all I’m doing is changing the pistons, getting new rings, new bearings, etc…
I don’t know too much about rebuilding bottom ends, so any info on what machining is required if any (if necessary, please give a detailed explanation of each item for machining, ie balancing crankshaft, what is that?), what measuring tools I need, etc…
HELP!!!
