bulbs for headlights
hello,
I want to learn more about the different light bulbs that I can use to replace my stock headlamps. What kind of bulbs can I use for the main Hi/Low beams (9006 series?) and fog lamps? Are they the same for the madtyteJDM headlights? What are the H4 and H4H bulbs I hear people talking about. I’ve also seen a thread by a sponsor here selling HID bulbs. What series would I need for the hi/low beams in the USDM or JDM headlights?
I wouldn’t be able to identify which bulbs are what if I saw them, so it would be very helpful if someone could answer this seemingly simple question.
thanks!
did you even take the time to run a search?
bulb application for both usdm and jdm headlights have been posted many times now.
http://www.g2ic.com/forums/showthread.php?t=56068&highlight=bulb+application
jdm - h4h
usdm - 9004
usdm/jdm fog - h3
h4 - usdm bulb simliar to h4h
search.
thanks! that was faster than I thought. I guess you got tired from answering the same question 2 weeks ago. It was already down at the bottom of the search page.
http://www.g2ic.com/forums/search.php?searchid=936014
i think there is also something in the teg tips section corresponding to your non searched topic
I looked in the “Lighting” section of the TEG TIPS™ , but I didn’t see anything. There was bulb replacement, installation, and JDM one piece renewing. But, I didn’t see anything specifically about which bulbs fit which headlight assembly.
