this is my first time attempting to make a DIY so bare with me.
what im going to show you, will change your bumper lights to the 94-01 integra bumper light setup. meaning they will come on with the day lights but they also will still blink.
estimated time 30mins - 1Hr
what you need…
-electrical tape
-solder
-soldering iron
-heat shrink
-extra wire ( I used a 14g wire)
- wire tap clips (lets you tap one wire into the other without cutting anything)
- 2 94-01 integra bumper light plugs
these are the bumper lights im taking about. you can get these at you local junkyard. not sure on the part number or anything.
LETS GET STARTED!
Remove your headlight. Not explaining can be looked up.
Remove the bumper light.
Remove the plug from the bumper light and cut the socket off as close as possible. want to leave as much wire as possible.
Now your left with 2 wires. strip about a 1/4 of an inch off the end of them.
-green
-black
now strip the wires from the 94-01 plug about 1/4"
-green
-black
-red
you will need to extended the red wire from the 94-01 socket
if you cut close enough to the stock bumper light socket you wont have to extend the green or black one.
what your going to do is connect the…
green - green
black - black
red - the red wire on the corner light. the corner light that comes on with the day lights
you will need to use the wire tap clip with the red wire and the corner light. basically it splices the bumper light into the corner light.
wrap everything up nice and tight with electrical tape. don’t want to have a short. remember the wires you are handling are pretty old.
everything back installed
this is what you get
VIDEO=====================================================
Here are some pictures of the new setup you installed.
hopefully this helps everyone out.
if you have any questions feel free to PM me
