Bumper Question Wrecked or missaligned?
I have question does this bumper look like its put on wrong? i’m notsure whats going on i replaced the fender and the left side looks like it’s on good but the right has like 1/2 inch gap can anyone help
yeah it looks like whoever put that bumper on didn’t align the holes for the bolts that mount onto the mounting blocks/brackets.
Take off your bumper light / turn signal and take a look, should be two bolts (12mm) there. Because i swear i did this once, where i put the top screw on the bottom hole without realizing it and it looked kinda like what yours looks like.
If that’s not the case you might have the wrong mounting blocks, what year is your car?
1990 yesterday i took the bumper off and the mounting block was bent from the right side like if someone pulled it out but i hit it with a hammer to see if i can straighten it out but it was still a little bent
try getting some other mounting blocks for the same year, also check if you bumper support (metal part of your bumper) is straight.
Ive bought enough bumpers to see all kinds of weird damage done to the bumper supports and mounting blocks that cause body panel alignment issues.
