Can the 92 4dr integra bumper fit the 90 2dr integra ?
yes as long as you also transfer the mounting blocks aswell
:search:
basically if u stay within the 90-91 or 92-93… both front and rear bumpers are EXACTLY the same between 2drs and 4drs. so yes like what BLKACK1 said, as long as u take the bumper supports and brackets from the year of the bumper u wanna use… and replace the ones on ur ride it’ll work.
Thanks alot
correction. 2dr and 4dr REAR bumpers are NOT the same.
well i bought a bought a bumper from the four door and it seems like a perfect fit for me
btw its for the back
weird, i swear the four door rear bumpers are longer. and the 92-93 rear bumper design was no different compared to the 90-91 on the four doors
the only problem i had was that the car is a JDM, like most of the DA out here, and the most of parts shop have the USDM.
sorry to thread jack but id didnt feel like making a whole other thread to ask this question.
i tried putting in a new bumper on my DA but there seems to be a gap where the headlight and bumper meet.is there any reason to this?
any suggestions is helpful.
I have the same problem as well here…
I’ve been thinking of using some extra washer’s…
I have about a 1/2 gap by the light and fender…
Could be that the car had been in an accident in its early life. Take a picture and some of us can really help you.
prior8t2000 Try taken the fender off and realign it back together.
Okay.
But I do have a 90 DA with a used 92 DA front bumper…
having a 92 bumper on a 90 should not pose a problem as far as i know, maybe the mounts are bend from an accident.
One of things that i know contributes to this, is that most persons sit on the sides and rest there foot on the bumpers, putting pressure on them hence they look like that.
i think im putting it on wrong.i saw a pic of the last front end that was on it and it sat flush unlike this one. so i wonder what im doing wrong.
can u prove it? cuz i can if u’d like to compare part numbers for rear bumpers.
I can prove it too…
90-91 2 dr rear 71501-SK7-A00ZZ FACE, RR. BUMPER
90-91 4 dr rear 71501-SK8-A00ZZ FACE, RR. BUMPER
92-93 2 dr rear 71501-SK7-A80ZZ FACE, RR. BUMPER
92-93 4 dr rear 71501-SK8-A00ZZ FACE, RR. BUMPER
So they are NOT the same
yeah SEE they are different lol… and if this is good fitment, you must be blind.
4dr bumpers are slightly longer on the sides…
Maybe it has to do with the trim JDM r USDM
I just got done switching from 90-91 into 92-93 bumper,support and mounting blocks but there’s a slight gap on the sides where the two screws are. Should I switch those brackets also to a 92-93 to get rid of the gap? Or are they the same? The gap isn’t that bad but I wanna fix it.
