Burfy's 93 DA build - Needs some love
So I didn’t post my DB1 build here, but I’ve decided to move on to bigger and better things. So I grabbed a DA for $300. It’s very rough around the edges, however the frame is 100% and I love Gen 2’s so IMO that’s all that matters!
4dr build:
http://www.cardomain.com/ride/3188315
Here’s a couple pics of how I received it:
When I got the car the guy who sold it to me said the starter was fried because he couldn’t start the car through the ignition. He had an extra one sitting in the trunk for me. I noticed there was a bunch of electrical hanging down under the dash but kept my mouth shut. He also mentioned it had a stock alarm. So right away it all made sense. I used a cotter pin and jumped 12v to the starter and surprise surprise it fired up and ran like a champ :giggle: I ripped out the Acura alarm and plugged in the stock harness and voila, key start! So with that out of the way, my next issue was the driver’s window being smashed. Fortunately I had an extra DA door kickin’ around with good glass so I whipped that in. I lubed the crap out of the sliders aha. I know they’re common for sticking. I picked up another hatch for cheap, doesn’t have any holes, verrrry little rust and it has a stock spoiler which works for me. The left side arch is spotless in terms of rust, but there’s rust further up the car which can easily be resolved. Still need a picture of that.
The power steering lines are rotted on it. The p/s pump is now removed and the fluid has been removed (accidentally hehe) from the system. I’m in the process of making an extra rack I had kicking around looped. I unbolted the 10mm and gutted the springs n’ things inside so there’s less resistance to fluid flow. I just gotta swap things eventually. I currently don’t have any pictures, but I’ll get some soon!
The brakes were completely destroyed :nonono: Whoever owned it before burned through the metal piece that the friction material is bonded to :eek: I replaced the left caliper obviously. Right side was surprisingly salvageable.
Left rear
Right rear
Fronts were still barely within MTO spec, but I got a full set, kind of. I bought all 4 wheels’ worth. Got the rears assembled fine, but when I went to assemble the fronts I found they were the wrong pads!
So, a little work on the grinder and I got:
I made sure to take it easy so they fit snug and still slide freely. Spent about 20 mins per pad. And fortunately they didn’t overhang the rotor. You can see in the pictures they line up perfectly:yeah:
I forgot to take a pic of the rears assembled without the wheel on but this should be a good enough teaser:
Got the wife to help me bleed the system too… She’s learning car stuff :drool:
I picked up a b16 tranny too. Ended up paying $180 for it in the end :slight_smile: I was expecting to redo the synchros in it but when I opened it up I found some things that are considered “un-good”.
Looks pretty right?
:eek: Where’s the magnet??
Ohh, that explains the magnet
Non-LSD :jack:
Yup, the input shaft bearing grenaded. Amazingly, no teeth were harmed :yeah: Sooo ya, since everything’s apart I’m getting a complete rebuild kit and now I’m looking for an LSD
Rebuild kit will be purchased here:
http://shop.synchrotech-transmissions.com/BSK-SYN103-B16-B18-Y1-S1-Bearing-Seal-and-Carbon-Synchro-KIt-BSK-SYN103.htm
or
http://www.teammfactory.com/carbon-moly-synchros
Since I don’t want to disable the car yet because I still like to play with my DB1, I decided to work on the suspension. I noticed the springs were broken. So tonight my bud and I shit-hammered the front end and got everything torn apart, lubed properly and reassembled in an hour haha. Nothing was anti-seized so it took some effort to crack things but nothing was seized thank god.
3-piece springs add 5hp :lol:
new height
Enjoy this “What not to do” video :naughty:
And just for fun, another “What not to do” and that’s park on country grass no matter how dry it looks because this happens:
I had to use my 2DR to pull it out because I was by myself :rolleyes:
Still tonnes to do!
More or less prioritized:
Rear suspension
Full bushing kit
Remove LS engine/tranny
Engine bay clean up
Wire tuck
Still deciding on engine set up (really interested in a reliable turbo set up)
Body work
Clean up interior
More updates and pics to come, stay tuned!
*excited to help you rip out all your suspension and the engine&trans when you buy your house
You and me both lol… I’m looking forward to getting your car rebushed so you can take me for a rip cuz you’re a jerk and didn’t take me out before ripping it apart :gay:
lol it wasn’t my fault that the studs snapped while i was loosening a wheel to swap it out so the incredibly low tread showing belts didn’t get us killed while we were rippin it haha
