Bushings
What bushings make the biggest noticable difference? im planning on getting the ES kit. but is noticeable when driving?
you will notice a pretty good difference with the ES master kit. the ride will be firmer and more responsive.
i have put in ES rear trailing arm bushings in my integra.
very noticeable, and much better.
You won’t be disappointed if you get the ES Hyperflex kit and OEM trailing arm bushings. If the bushings have never been replaced on your car then the bushings should be near the top of your list of “maintenance” items you need to replaced. You can’t expect any aftermarket suspension components to function properly or yield their full potential unless you first take care of worn out bushings, rod ends, ball joints…etc
