- both were running OK before being pulled - drove to SF & Reno no problem (few hundred miles over a mountain pass)
- engine has moderate oil leak, not quite dripping but had covered underside before being pulled, not sure from where
[I][B]$250 o.b.o. B18A1 Engine Only[/B][/I]
Fresno Area
I have hoist, chain, and hardware (bolt and carabiners to attach chain to), to load. All U need is a Pick-Up Truck or Semi
Some photos:
Few More:
http://www.302found.com/shell_motor0616/
MOTOR-ONLY
$250 O.B.O.
CALL TODAY!!!
:salute:
[QUOTE=sloppysleeper;2334912
MOTOR-ONLY …or… TRANS-ONLY
$250 O.B.O.
CALL TODAY!!!
What is your contact number? I can take the LS tranny off your hands
sorry man, I’m going b20b with this biotch and nobody is buying my shell so may-as-well use it. Timing is funny with this since you’re making an offer but I’m gonna bolt this slightly-worn but still good ys1 trans to the b20 and try to sell the b18 engine.
B18a was running fine before I pulled it. Had a moderate oil leak – valve cover gasket, worse case head gasket?? Made it from S.F. to Reno and back over to Fresno no issues at all other than the oil leak, added maybe 1/3 quart in 500 miles,… you make the call $250 o.b.o. :excite:
[QUOTE=sloppysleeper;2335180]sorry man, I’m going b20b with this biotch and nobody is buying my shell so may-as-well use it. Timing is funny with this since you’re making an offer but I’m gonna bolt this slightly-worn but still good ys1 trans to the b20 and try to sell the b18 engine.
B18a was running fine before I pulled it. Had a moderate oil leak – valve cover gasket, worse case head gasket?? Made it from S.F. to Reno and back over to Fresno no issues at all other than the oil leak, added maybe 1/3 quart in 500 miles,… you make the call $250 o.b.o. :excite:[/QUOTE]
sorry I just need a YS1 LS or GSR transmission, if you change your mind then let me know. thanks.
