[QUOTE=polobreaka;2330747]i am currently using a DC integra linkage and it feels much better than the DA version. It is a little longer so your shifter might sit closer to you.
if you insist on using the DA one, im much more local to you since i am in North OC (Huntington Beach). Let me know if you are still interested.[/QUOTE]
I’m interested. Is there anything wrong with the linkage, specifically the change rod? As long as the rod isn’t damaged, I could drive up sometime Saturday if your available.
To confirm, you guys have both bars installed? I don’t have these issues at all. I’m using a TWM dual bend shifter made for DC2. As you can see my shifter sits a bit closer to me due to the dual bend, but even if it was reg bend, it won’t sit right in the middle. the position in pic is neutral. it sits pretty straight up. 1st gear isnt too far forward either.
I have an extra linkage askin $40 only thing is you need new bushings and comes with a short shifter. Im located in lake elsinore. Text me at 951-378-0780
