Hey guys, I’ve got some stuff for sale. Prices do not include shipping or PayPal. Contact me here or by text- 530-321-9334
Email- michaelessila@gmail.com
Skunk 2 throttle body, Tps sensor screw broke and will need to be tapped out. Otherwise in good condition $90 obo
Skunkworks coilover springs 10k spring rates $60 obo
Tein springs $35 obo
OEM ITR valve springs $50 OBO
I bought these from a member here and after having a machine shop pressure test them I found out 3 of the intake springs have a higher seat pressure than the rest so its not a complete set. I will part out!
8 exhaust outer springs
8 exhaust inner springs
16 retainers
8 intake inner springs
5 intake outer springs
3 aftermarket outter springs (10 lbs higher spring seat pressure)
The Skunkworks are10k which is approximately 560 lbs. I can’t find any info on the Teins. They are a bit longer though, possibly just lowering springs? I’m not sure, they came on my blown yellows… both can be used on the front or rear depending on what rates you want to run in the front or rear.
[QUOTE=rollinmyda;2302624]Ground control coilover springs sold!
The Skunkworks are10k which is approximately 560 lbs. I can’t find any info on the Teins. They are a bit longer though, possibly just lowering springs? I’m not sure, they came on my blown yellows… both can be used on the front or rear depending on what rates you want to run in the front or rear.[/QUOTE]
Damn too late on the eibach haha I was hoping its about 350 to 400 lbs 560 is too much for a DD.
I also have some blue samco sport silicon radiator hoses I’ll be adding along with a ton of OEM parts as I go through my garage. I’m sure I’ll find more aftermarket stuff I will be looking to part ways with too so check back! I’m getting the keys to my new place tomorrow so I’ll be constantly adding stuff for a while.
The smaller ones are uca bushings. The larger ones are for the lca’s, not sure if they’re front or rear. I’d have to cross reference them against my full kit.
