Info…
My car 91 integra LS special 5spd
Harness is from 90 integra GS Automatic
(The harness im talkin bout is the on that runs to the headlights and under the dash connects to the ecu and what not)
Well my original harness was hacked to sh*t so i got this harness from the 90 GS it was a auto car for free. I need to know if it works or not…it looks like everything plugs right in besides where it connects to the auto shifter and i think it might be missin one plug that connects onto the clutch pedal.
hope you are ready for some fun…you pretty much have to take your dash out, and everything associated with it. that is, if you are trying to swap harnesses?? i believe i read your post correctly…
why dont you try to fix the existing harness in the car?? it will be easier than pulling every inch of wire out of the car and swapping…just sayin’. it is a pain-in-the-A, cuz i just dealt with installing an entire harness myself.
oh yeah i know… i already did all that my old harness was basically useless…i know how to get it out and all but the clutch pedal has 2 plugs for it that comes from the chassis harness…the new one only has one plug…so any ideas?
the new harness you are putting IN only has one plug, right??
okay, what i did, was just put a jumper on the (upper ?) clutch pedal switch. i think this is the one that allows the car to start - only if the clutch pedal is depressed. (dont quote me on that) but im pretty sure. and yes, i have in fact started the car with no isssues.
seems to me like a safety thing that honda put in, so you cant just start the car in gear, you have to be pushing in the clutch pedal…
