cable to hydro front motor mount ?'s
So I did the Hasport cable to hydro conversion with my jdm b16. I have a 99/00 Civic transmission. I also have a Neuspeed front strut bar. Because of not being able to utalize the front motor mount, the motor is moving so much it’s hitting the strut bar. What can I do??? I was ready about Innovative making a conversion to use the front motor mount. I’m on a tight budget too so that doesn’t help the situation. What are my options?
you need harder motor mount inserts. the rear one needs to be super stiff and the driverside one needs to be atleast somewhat hard.
Since your minus one motor mount, you need to go after market. I have 2 hasport mounts (tranny, driver side) and stock rear mount. I have yet to have a problem with engine movement. As far as money goes, the mounts are worth every penny, especially considering the work load 3 mounts have instead of 4.
can someone point in the direction of the motor mounts? What brands? Are there any other applications that work? Can I use DC mounts? Any Civic Mounts? I know the rear DC mount is different.
nope. you need da mounts. call up g2ic sponsor xenocron. he will set you up with some avid mounts for a good price and if you don’t already have a set i would consider the avid traction bars too.
