Cam gears
I have a JG pro series head, 4-1 header, chip, test pipe, cai… I’m going to be buying some 404s later on… but for now can someone give me an idea what to dial my cam gears in at… I know I should put it on the dyno… But what are some of the number combos I can use. I was thinking of advancing the intake 1*.
myself personally wouldnt really mess with the gear settings unless you are all out racing and need the exact timing, especially if they are stock cams you wont gain much. if they are after market cams call the cam manufacturer and get the timing numbers. but yeah the dyno will tell you for sure where you gain and lose HP.
