camber degrees
will 2 degrees be good enuff for around 2-2.5 inch drop?
My 2" drop on Neuspeed Race springs put my rear camber at about -2.5 degrees.
neuspeed race springs give more than a 2" drop. i believe its a 2.5" drop. a 2" drop won’t give you -2.5 degrees.
i had progress sport springs previously (2" drop), and i had between -1.8 and -2.1 degrees
a little bit of negative camber is fine. If you’re only dropped 2" you’ll probably want a kit that can adjust from 1.5-2.0 degrees. That will cover what you need.
Originally posted by 91IntegGS
[B]neuspeed race springs give more than a 2" drop. i believe its a 2.5" drop. a 2" drop won’t give you -2.5 degrees.
a little bit of negative camber is fine. If you’re only dropped 2" you’ll probably want a kit that can adjust from 1.5-2.0 degrees. That will cover what you need. [/B]
It is a 2" drop all around.
http://www.neuspeed.com/order/index.php?action=1
Of course camber will differ from car to car, especially since our cars have been beaten on at varied levels after 9-12years. Heck, my right rear and left rear have different camber.
My teg is on Neuspeed Race and its 2inches all around, u can get the Ingalls Extreme Front camber kit for $130shipped @ www.groupbuycenter.com HTH, the kit will adjust ur camber up to 3 degrees so u’ll be fine.
Thanh
huh, looks like i am wrong. i guess the kid i know who has the neuspeeds cut a coil or so. 2.5 degrees seems like a lot of camber for a 2" drop.
the rear difference could be partially due to the rear trailing arms. I know my rear is about 1/4" different from side to side. Luckily i have coilovers so i could even it out.
so how many degrees of camber adjustment do I need for a 2.5" front and 2.25" rear drop?
I dropped my car last week with Neuspeed Sports, 1.8 all around. It threw my camber off by 2.25 degrees up front, just so you have something to compare to. You will need the ingall’s extreme kit, it worked perfect!
