Ive got tokico blues on neuspeed sport springs, and have noticed the rear camber looks way off, but the front looks cool. How much of a degree adjustment would I need for functionality purposes, and do I need to do the fronts too? Camber kits Ingals with just 3/4 a degree of adjustment are cheap, but anything more is way more $$$…
Get yourself some $0.10 washers and you’ll be fine. Check in the teg tips section and you’ll know what I’m talking about. Just use washers instead of the shims. I put one washer under each bolt(that’s 2 on each side) but I still noticed some wear so I added another washer to each bolt. I think it’s pretty darn close to perfect now. I also have a 1.8" drop so try that and see if it works. You may want to rotate your tires front to back also so the tires on the rear now don’t get worn down too much.
