Camber Kits
I’m lowering my car 1.8 inches on H&R Springs and KYB GR-2 Struts. My question is, do I need a camber adjustment kit for a 1.8 inch drop? If so what brand should I use and can anyone direct me where to buy them online? Also I’m kind of confused as to what to use in the rear. I know I need a camber kit for each of the front wheels, but do I use the same kind of kit for the rear or is there another “tool” or product I need for the rear tires?
I have the neuspeed sports(basically the same 1.8" drop you have). A camber kit is highly required for this drop. I had one put on when I had the springs installed. I got an ingall’s camber kit for the front and purchased it from b17a.com. As for the rear I used the ol’ washer trick where you add washers or shims to correct the camber. You can find info on this in the teg tips section. If you have any more questions feel free to ask. HTH.
whiteyg2RS - How many washers did you use in each bolt and how thick were they???
