camber problem and im clueless
i went in to a tire shop for a front end alignment and and it turns out my rear passenger tire is tilted 1 degree. so he said i needed a new camber and its about $120-140 installed. i was wondering how much the parts are and is it hard to do yourself? or if its even worth doing because you can hardly tell. also would a rear lower sway bar help at all or even effect it? anyway im clueless about this so any help would help. thanks
Go to Teg Tips >> Exterior >> Correcting Rear Camber (With Pictures)
for the camber: gsr2nv is right, check the teg tips. very cheap and easy fix.
the sway bar has nothing to do with your alignment. But a bigger sway bar will help handling dramatically.
