Can a 95 GSr crank fit in a b16a motor?
Can a 95 GSR crankshaft fit into a b16a motor and what rods would i need?
You would have to use custom rods and custom pistons with a shorter skirt. If you were to use custom rods with factory style pistons, then the skirts of the pistons could possibly touch the crank and definitely would not be able to clear the oil jets. Compression would also be off the charts with factory domed pistons with a stroke that long and a cylinder that short. I do believe the toda stroker kit comes with custom pistons for a reason.
