can i skip the tranny roll pin and pull the entire linkage out with engine?
i can’t get the roll pin out, can i just disconnect the one bolt under the shifter and pull the entire linkage out with the engine? it looks like it would work but has anyone ever tried this? any suggestions? (keep in mind i’ve tried the c clamp trick and i’m doing this swap in my driveway on jacks) thanks
It would be easier to drop the engine out the bottom with the linkage still attached.
Or you could drop the transmission with shift linkage still attached from the bottom, and pull the engine out from the top.
[QUOTE=BoonyBoun;2168579]It would be easier to drop the engine out the bottom with the linkage still attached.
Or you could drop the transmission with shift linkage still attached from the bottom, and pull the engine out from the top.[/QUOTE]
well how hard would it be just to pull the engine itself but leave the tranny in, cuz i don’t really need to pull the tranny, i just heard it was easier that way, but right now it seems easier to just pull the engine and not the tranny…
yes you can.you have to do it at an angle.its easier when its right in front of you.i’ve pulled 6 engines and i never messed with the bitch pin.just unbolted where the shifter is.
yeah i just finished unbolting it, looks like it’ll be fine Thanks man
yeah i’ve done that before. it works.
i’ve pulled the engine out with the linkage attached. Its a REAL PITA without a lift. I Suggest raising the car up as much as possible to have ground clearance with the linkage. Make sure your engine hoist can still clear the car though.
If you’re pulling the motor with the linkage you need to be careful not to bend the shift linkage when lifting the engine out of the bay. I’ve seen it happen multiple times. (it gets stuck under the subframe)
