i dont think so, due to the fact that if you disconnect the high beam wires from the switch, then you have no high beams, whereas if you wire up a new switch, then you can use your fogs seperately from the low beam/high beam but can also can use the fog light as a high beam as normal. Im sorry about the confusion, but the reason i did this was to keep my high beams as normal, and have a fog light!
but does that mean when u turn ur high beams on ur fogs go on as well ??
what i wanna do is have the choice of using my fogs with high or low beam… if you know what i mean…
