I have a 92 gs Integra
5spd
304144km on her
Pros: aftermarket deck with USB and speakers
Set of winters on stock rims, set of aftermarket rims with good tread
Skunk2 short shift (not installed)
H&R lowering springs( not installed)
4-5" muffler tip ( fart can, not installed) with 1 1/2 ft piping on it still
Euro taillights( not installed, clean)
1 piece angel eyes headlights(not installed, clean)
Front upper strut bar( not installed, not sure brand)
Aftermarket steering wheel with hub(not installed, AEM cold air intake with magnaflow cone reusable cone filter
not sure brand)
LED taillights( bulbs swapped)
LED dome
LED map
New high flow OEM fuel pump installed about a month ago
New RPT distributor installed about 2 months ago
New right upper control arm( installed)
Used newer exhaust. headers 4-2-1 ( DC?) New cat installed about 3 months ago, has 2 resonators and a duel muffler tip ( fart can style)
New plugs new wires
Timing belt and water pump done about 6 months ago.
O2 sensor replaced about 2 months ago
New valve cover gasket kit with rings( not installed)
Clear side markers( installed, also have the orange stock ones)
Runs really good
Good on fuel
No grinds. no slipping
Not obnoxiously loud cause of the cat and 2 resonators
Clean interior
No rust(Atleast none that I can see)
Windshield replaced about 2 months ago
Cons:
Power steering pump is leaking a little.
1 dent on drivers side front fender above wheel
Owner before me didn’t do a great job painting it blue, but doesn’t look bad, just a couple spots are ruff and kinda orange peeled,
Front bumper has some paint transfer from a underground parking poll so a little yellow
Possibly a alignment needs done at some point not bad though
No knocking, does tick SOMETIMES on warm up Prlly need a valve job at some point
Was on a VI bit got her passed
ABS light is on, right rear sensor needs to be replaced or cleaned.
Everything works, starts everytime, but for a 20+ year vehical it does have quarks every once in awhile, some connections probably need cleaning
An example is the running lights work, but SOMETIMES the relay needs a tap.
Any other info to help you help me just let me know.
Thanks in advance
And will get some pic up soon
Oh and has a 12 comp kicker RT boxed, with a 1000watt max amp
Thanks again
