can't adjust idle screw!!!
Yeah thats right, when i turn the idle screw nothing happens, its stuck at 1900! any ideas?
you might have a vacumm leak :shock:
damn fuel injected motors!!!
you have lots of carbon build up inside the throttle body. You might try taking the screw completely out and cleaning the screw and the hole with some good throttle body cleaner spray. If that does’nt help. You are going to have to remove the TB and go over it with a toothbrush and cleaner. Advice:replace the TB gasket when you do this. Acura/Honda should stock the gasket. Hope this helps
