I tried to get my bumper off, but after i thought i had it…i foung a bolt under each headlight. I tried to get the headlights off my 4 door but couldnt. Please help
There are the 2 phillips head screws in each wheelwell, the 4 bolts that are behind the 2 bumper turn signals and the two bolts (Black phillips head bumper bolts) at the front bottom of the bumper cover. They are twords the rear of the bumper cover on the bottom between the bottom lip and the splash guards.
It seems thet there is a bolt behind each headlight also, and I cant get to them. Any ideas?
Nope, none behind the head lights. Just do this:
1)remove the 4 phillips head screws(2 on each side of the bumper) in the wheel wells
- remove any screws holding the splash guard to the bottom of the car(no need to take off the lip)
3)remove each turn signal w/ a phillips head screwdriver and undo the bolts (2 behind each light)
4)that’s it, hope it helps
Originally posted by C.K. James
[B]
It seems thet there is a bolt behind each headlight also, and I cant get to them. Any ideas? [/B]
The only bolts or screws to remove the front bumper and cover were listed in my post. I’ve removed dozens of G2 front bumpers
Are you removing the bumper to install 1piece headlights? If so you have to pull the front bumper and cover off to get access to the two bolts that hold the USDM headlight brackets to the radiator support.
