car cranks but wont start
It can’t be that simple…
I’m sure there would be other indicators if it was a relay. At first the S4 light kept flashing, but I managed to make that go away. I noticed that the 3rd brake light comes on immediately when I hook up the battery… What relay are you referring to(if you’re talking to me)?
[QUOTE=ALLHAILG2;1740092]It can’t be that simple…
I’m sure there would be other indicators if it was a relay. At first the S4 light kept flashing, but I managed to make that go away. I noticed that the 3rd brake light comes on immediately when I hook up the battery… What relay are you referring to(if you’re talking to me)?[/QUOTE]
if your talking to the other guy, then no your relay isnt your problem, if you hear the fuel pump prime and you’ve had it started off of a charger before then your relay is functioning properly
if your talking to me, then yes it can be very simple.
your 3rd brake light comes on when you hook up the battery?? i’d check over your wiring, if thats happening then you probably have a short somewhere and thats draining your battery to the point your car cant crank
