Hey forum.
So it fking happened again, taking my sister to class and my 90 DA sputtered off, barely made it into a parking lot. But when she cools down after an hour she starts right back up like nothing happened!
I recently rebuilt my distributor with a new coil pack, and igniter/icm with fresh thermal compound on the ICM.
Now obviously i searched and found all kinds of info, and honestly this is one of the most difficult things to troubleshoot, i get no CEL, (obd 0). And this issue seemed to have gotten worse, it used to be that she wouldnt start when hot, after a short drive, now she dies while driving slow or stop/go traffic and wont start back up until she cools, i also take the negative off the battery.
Parts replaced in the last 3 years that might be related:
Fuel pump/sock
Main relay
Fuel filter
*I also use injector cleaner once a month
NGK plugs/wires
New coil pack/ICM
Things i suspect but I’m not sure on:
Timing, ignition/mechanical. I wasnt able to get my car timed since shorting the jumper in the passenger footwell does nothing.
Throttle Position Sensor, i also have a slight hesitation when accelerating sometimes.
Coolant Temp Sensor, from my exp with Euro cars, these sensors tell the ECU the car is a lot hotter than it is and will keep the car from starting.
Fuel injectors, lord i hope not $_$
Being unemployed i don’t have the funds to just guess and throw parts at the car.
Side note, and maybe unrelated but when i shut the engine off i don’t hear that sucking/vacuum sound coming from the intake like i used to.
Thanks for reading my novel, and please leave your feedback, the info im getting from web searches and friends is all over the place!
