car doesn't turn over. Starter perhaps?
This cold morning I turned the key to get it to start and I get nothing. I do hear the fuel relay click. Lights, radio, power windows work fine. Checked the battery with a mulitmeter and It’s reading 12 volts. So the battery is good.
What do you think needs replacing?
Try push starting it. If it cranks over, its probably not your starter.
Could be a positive battery cable/terminal not getting supply.
I’ve also tried jumpstarting it. No avail. No crank. I have no one right now to push start it. Help I need to get out of my house.
I re did my positive and neg cables with OEM ones. Cleaned out surface contacts and all.
I had this same problem and it was the starter.
By the way i would always push start it before i replaced the starter. So if it turns over when you push start it, it could still be your starter.
[QUOTE=The_Oz;278199]INTRODUCTION
[u]BASIC TROUBLESHOOTING GUIDE[/u]
Engine will not rotate when attempting to start
  • Battery terminal connections loose or corroded.
  • Battery discharged or faulty.
  • Automatic Transmission/transaxle not completely engaged in Park mode or Manual Transmission Clutch not completely depressed.
  • Broken, loose or disconnected wiring in the starting circuit.
  • Starter motor pinion jammed in flywheel ring gear.
  • Starter solenoid faulty.
  • Starter motor faulty.
  • Ignition switch faulty.
  • Starter pinion or flywheel teeth worn or broken.
Thanks man. Thats what I thought it would be. If you guys want an update after I install a new starter let me know.
Well yea, push starting it on could still mean the starter is bad, but a blown radio fuse could cause the car to not start too, its just not “that” common of an occurance.
Really? Anyways Akira let us know what happens. It sounds like it could be your starter. Like when I did a coolant flush on my 88 accord one of the starter wires came loose and I could’nt figure out y it wouldn’t start and there it was, one of the starter wires got taken off somehow put it back on and she fired right up.
Well, I just replaced the OEM denso starter last week for a reman and now my starting issues are gone. No starting delays anymore. Meaning, With the key turned all the way to the start position, I used to get about three seconds of quiteness before the starter engages to start the engine. And sometimes it wont start at all even with a jumpstart. With the new starter, problems gone.
Thanks guy for helping out.
