Car flooding even after....
Okay so I’ve done the teg tip on how to fix the wet passenger floor board, thought it was fixed. Now that rainy season is back it looks like the damn leak is back. So I ripped apart the wiper cowl area again and checked to be sure. Everything is in place and looks fine. WHY AM I STILL FLOATING?! Is there a DRAINAGE hole under the wiper cowl that may be clogged with leaves and sh!t?
i have the same promblem i did the teg tip thing put it stills leaks
som 1 help!!!
Make sure the white rectangle clips above the air fan box are sealed aginst the metal. If not use some plumbing tape (not really tape, its used when screwing two pieces of pipe together to prevent leaks). It worked for me, HTH
shelby-------- where the hell you been!!! were gonna have a tampa meet. check the thread.
STEVE! I’ve been “gettin my school on”. :slight_smile:
Network engineering degrees leave no time for much else. :slight_smile:
do you think you’ll have time, say… noonish till 3ish on sunday, july 21st??
it’s called teflon tape, you can get it at any hardware store
mines leak on the passenger side but i can seem to find where it comes from… all i know is that my mats get soaked…
