while driving the car stalls when you give it a little gas above 2000 rpm. it feels like it looses power but then about 3000rpm it acts if nothing has happened… what could cause this? i was thinkin maybe the fuel filter, spark plugs and or wires? thanks in advance
i asked the same exact question. i can’t figure it out
A cramp in your leg. Not enough info, how bad is the hesitation? Any weird sounds?
i cant hear anything weird… the hesitation was noticed when getting on the highway and then again in town, its like you went to go and if you didnt shift before 2500 or after 3k then it would feel like it stalled.
I have the same problem but cant figure out what it is. When I step on the gas it goes but with some hesitation, then once it hits about 2500 - 3000 it drives with more power. Under 2500 in first gear is as if something is holding it back.
how many miles do you have?
Check your oil, and…
Try some fuel injector cleaner
I had the same thing… I took it to honda and they told me that my injectors were going bad…
I found that fuel injector cleaner would make them work as long as i was running it in the fuel… when i wasnt it would run like crap…
I swapped them out with another teg i had.
If you have another teg laying around try that…
also try changing the fuel filter.
If not i have 2 tegs parts cars I could sell you 4 of the ones that i have. let me know.
Just some ideas:
Clogged catalytic converter
have muffler shop test it, or unbolt it and do a visual inspection.
Bad O2 Sensor, or wire signal
Bad Ignition Coil
umm… whatelse
