I just changed the spark plugs, cap rotor.
Morning cold start, the idle would just drop unless i gas it to keep it started and running so i can warm up the engine.
When I gas it half way or on normal take off, the car would sound and run like its only powered by 2 or 3 cyl. through 0-3k rpm only. After 3k rpm it would run fine like normal.
When I turn on the A/C, the idle is rough and would drop, causing the car to die out if im at a stop. I have to gas it a little to make sure the car idle doesnt drop.
I dont know if this has to do with the problem but my distributor bearing is messed up, I have a brand new distributor on its way.
Any help would be great!
