car not blowin air
hello ive looked everywhere in search but cant find my answer i just changed my heater blower cause it was not working now it works but when i turn my heater on it does not blow alot of air i can hear the blower but the air is not coming through the vents just a little bit
well im guessin you mean blower motor? and is the air warm? if the airs cold then its prob your thermostat
sounds like a stuck flap or a vaccum leak
sounds like you might have a clogged vent.
try testing all of the different vent configurations to see if they are all the same or if the air blows at different velocities. If there is a clog, this would help pinpoint the location of it. Also listed to hear the vent switching when you select each setting, you might have a broken selector that is dispersing your air to only one set of vents that you are not feeling at.
check your fuses blower motor relay
heater issues… sounds like leo’s specialty. :angel:
