Go here for the Helms manual:
http://blackteg0.tripod.com/g2integra/index.html
If you can’t replace your air filter and check your tire pressure, then you don’t deserve to own an Acura:)
As for the fuel filter, don’t worry about relieving the fuel pressure. You don’t have to do it. It’s a safety precaution that Haynes always print on their books to cover their A$$es. Just make sure you surround the fuel filter with a lot of rags to prevent fuel from spilling all over the place once you loosen those bolts. I also advise to use a Vice grip (use it very gently though) to loosen one of the bolts.
With ignition timing, you need a timing light. Basic one costs $45 plus taxes in your neighbourhood Crappy Tire. Consult both the Teg Tips section and your Haynes manual to check and adjust your timing. This might be a good time to advance the timing, but please be aware to use high octane gas (I highly recommend Sunoco Ultra 94 first, with Petro Canada 94 second).
With the distrib. cap & rotor, well I’ve never changed these, but looking at the Haynes manual and consulting the cap itself, it looks like a simple job. Just make sure you write down which spark plug wire connects to where, or else you’re asking for trouble.
PCV valve is quite simple. The problem you’ll face is that the valve is quite hard to get at. If you got small hands, then you’re clear. You’ll most likely won’t need any tools to replace this. Consult the Helms manual for location since the Haynes is quite confusing.
For coolant quality, grab yourself a $5 Motomaster coolant tester from Crappy Tire. Follow the instructions, and you’re set to go. If you plan on replacing your coolant, I suggest purchasing Havoline Long Life or Motomaster Long Life instead of the regular kind.
I also suggest doing an ECU reset. Consult the Teg tips for proper ECU reset procedures.
As for tools, buy Motomaster or Craftsman only. Snap-On is quite expensive. If it doesn’t say Motomaster/Craftsman on that socket/ratchet, consider yourself fu(ked. As for torque wrenches, you can buy the regular Motomaster scale torque wrench for $20 at Crappy Tire. The dial torque ratchet is the most convenient but costs $90. You’ll get by on certain jobs with just the scale-kind torque wrench.
Regards,
Oz
