Car shutts off while driving....
Hey guys, i know that there is a lot of threas on car not starting…but what about the car shutting off while you are driving? Heres the thing…i bout this car about a year ago…it’s been sitting in the drive way the whole time…i finally got a tag for it the other day…i changed out the old and radiator fluids…I was driving it to work and it cuts off on me in the middle of a very busy road…i was very embarrassed…i try start it and it won’t start…i sat there for abut 5 minutes trying to figuer out what was wront with it. I tryed it agian and it starts…i got home…i drove it again and same thing. The car will shut off once the engien gets warmed up…I’ve changed out the Fule relay and the main relay…still having this problem…Any ideas?
maybe alternator and/or battery
changed…
both have been changed too…
possibly check and double check all grounds to be clean and tight then???
Ignition switch?
[QUOTE=N FUL FX;2100544]Ignition switch?[/QUOTE]:werd: I think another guy a couple weeks ago had this problem and it ended up bein the ignition switch.
If the rpm’s drop instantly while driving to 0 it could be a bad ignitor inside the distributor. Ive had my car die a few times while driving…
Twice it was a bad ignitor, once was bad alternator, and a few times it sputtered and died and that was Main Fuel Relay.
Twice it was a bad ignitor, once was bad alternator, and a few times it sputtered and died and that was Main Fuel Relay. Good Luck!
thanks for all the input…i’ll change out the distributor tomorrow and see if that is the problem…once again, thanks guys…
Might want to also check the coil, had one do the same when it got warmed up.
doubt its the altanator bc it does crank but the ignition modual and coils are more likely let us know
+1 to the ignition module. Have had this happen 4 times in the last 3 years and it was the ignition module. (ICM inside the distributor)
It should come with some goo. If its clear its NOT dielectric grease. Its heatsink grease. I had one fail on me because I did not use the grease where it attaches to the plate. Overheated the ICM.
Also, if you have time, go to a hardware store and get a hex head screw for the rotor in the distributor. Its an easy mod, and will help with you replace the rotorcap later on.
+2 for Ignition Control Module. Also might want to check the coil and the Starter Relay first, its alot cheaper.
I had my ignition switch go out on me. Next time your car dies out on you check if your instrument cluster lights still come on. On my car the cluster will completely die out & that was one of the signs that it was the switch. Got another one from the boneyard for $10 and it “was good as new”.
hope this helps…
thanks for all the in-put…i’ve changed out the whole distributro and have not a problem so far…knock on wood…Well keep you guys posted if anything happens…Thanks so much…g2ic rocks…:rockon:
